won't idle, but runs?
Old Jan 5, 2006 | 09:16 PM
NL400sbc's Avatar
Car: 84 z28
Engine: 400 SBC
Transmission: Th-350
Hey guys, this is my first post here and i just recently compled a rebuild of a sbc 400, 2.02 heads, torker 2 intake and holley 750dp feeding the beast. The carb has been also rebuilt.
I can't get the car to idle at all, but if i start it and stay on the gas she runs good, as soon as i let off it dies. The primary jets in the car are 86's I believe, I was thinking that it may need larger jets.
Any help much appreciated.
Old Jan 5, 2006 | 11:10 PM
yzinger1's Avatar
Car: 1991 transam,gunmetal,t-tops,
Engine: 305,.030,k&n,airfoil,3inch exhaust,flowmaster80
Transmission: 700 r4
Axle/Gears: 4:10 posi unit
wont idle
it sounds like a vacuum leak, get someone to keep the engine running ,get some wd 40 and spray around the base of the carb ,if it idles its the carb gasket ,if this doesnt work spray between the heads and intake if this works its the intake gaskets ,if not check all vacuum hoses hope this helps jimmy
Old Jan 6, 2006 | 01:06 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Vacuum leak like he said.
Improper initial timing could be a factor too.
Does it stumble and stutter or just die out on you?
later
Jeremy
Old Jan 6, 2006 | 01:32 AM
NL400sbc's Avatar
Car: 84 z28
Engine: 400 SBC
it just dies out, runs perfect with a litttle gas. I did have my throttle plate welded and I had to grind the weld down on the side of the flange so the acc pump cover would clear, it may be possible that i never grinded enough off for the carb body to sit flush.
Still too cold up here to even try to pick at the car lol.
Old Jan 7, 2006 | 02:06 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Check your other post about the camshaft.
Will want greatly increased initial timing at idle.
Jetting for a 750Dp should be 70-72 primary and 80-83 sec.
You'll need a 3.5 or 4.5" power valve with the Blue racer cam
Old Sep 6, 2012 | 06:06 AM
Alex McEathron's Avatar
Re: won't idle, but runs?
Hey guys i have a 400 sbc in my 89 camaro...it used to run with a ticking in the valve covers.....well i took it out on the road and dumped the clutch and watched the smoke fly well i pulled her in the drive way and now she spits and sputters and when i give it gas it seems to has a vibrating sound in the exhaust.....could it be lifters?....valves?.....pushrods?......or what?
Old Sep 6, 2012 | 07:26 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Alex the thread you posted to is six years old. Keep an eye open on the dates. Welcome to Thirdgen.
eightsixseven
Dec 16, 2024 01:50 PM
camaro71633
Sep 1, 2015 10:24 AM
justin57
Aug 20, 2015 07:05 PM
zeitghaist
Aug 18, 2015 07:33 AM
squiggy2
Aug 9, 2015 09:30 PM
