Where to tie AFPR Vacuum line into Miniram Intake???
Old Jan 6, 2006 | 04:21 PM
Anniversary-Z-man's Avatar
Car: 1992 25th Anniversary Z28
Engine: 6.3L - 383
Transmission: 700R4; Vig 3200
Since the MR only has the 4 vac. inlets, I'm unsure where to tie the AFPR line into. On the drivers side, I have the brake booster in one and the PCV into the other, on the pass. side I have the MAP sensor in one and the heater/vent line in the other....I think that one has a valve tied into it as well. What's the best way to tie the AFPR line in??? Is it as simple and throwing a small Tee into the heater/vent line? Would that be best?
- Joel
Old Jan 6, 2006 | 07:41 PM
Tee it off the same place as the MAP; since there is essentially no "flow" in that line. That would be better than sharing the HVAC one. Make sure both pieces of line are as short as possible, and preferably made out of the hard plastic tubing rather than rubber.
Old Jan 8, 2006 | 01:51 PM
Engine: 6.3L - 383
Thank you very much! That makes alot of sense.
- Joel
LT1Formula
20
Nov 14, 2015 12:02 AM
Jote4805
Aug 25, 2015 06:11 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
apie2546
Aug 10, 2015 05:43 PM
