Fuel Injectors
Old Jan 16, 2006 | 12:53 AM
1991 RS/SS's Avatar
Car: 1991 Camaro RS
Engine: 383 LT1
Axle/Gears: 4.10
Fuel Injectors
I know there are a few places to post a topic like this, but this seemed best to me. Mods, if you think there is a better place please move it, thanks.
Anyway, I have some basic fuel injector questions. I increased displacement, so I am puting in bigger injectors. I have some Audi 28 lb. injectors made by bosch (they look exactly like the accel injectors without the yellow) that I would like to use, but want to make sure they will work.
1) I measured the impedance with a VOM and my OEM injectors are about 12 ohms where the audi injectors ane about 14 - 15 ohms, will this make a difference?
2) The plastic hat on the pintle (think that is the right word) on 3 of them is cracked, will that make a difference?
3) are the ford racing injectors a direct fit if these will not work, and if so, when I order the ford injectors is it worth it to spend an extra $130 on a matched set?
Thanks in advance
Old Jan 17, 2006 | 06:16 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Re: Fuel Injectors
Ide say you should have a matched set, I run 30lb SVO injectors. About your other question, i THINK that if the stock injectors impedance is lower and you use the audi ones... they will never fully open up(Unless of course you edit the prom). BTW, I wouldn't put cracked injectors in my car.
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
