fuel pump humm
Old Jan 16, 2006 | 04:24 PM
anything-z's Avatar
Car: 86 Iroc
Engine: 87 305 tpi
Transmission: auto
fuel pump humm
im getting an extra loud humming noise coming from the back of the car just behind the rear seat. the noise is constant now whereas maybe a couple of weeks ago i didnt really notice it. is this the fuel pump going bad and if so whats the average price to replace on these things? car is starting to have a wierd surging to it now too, mainly at stop lights. feels like its going to die right when i hit the brakes then the power comes right back.
also i have seen that someone made an access panel to their fuel pump, is this advisable or should i let someone else handle this?
Old Jan 16, 2006 | 05:38 PM
1991 RS/SS's Avatar
Car: 1991 Camaro RS
Engine: 383 LT1
Axle/Gears: 4.10
First thing I would try is a new fuel filter. If that doesnt help, then go from there as the fuel pumps are a pain to swap.
The loud humm could be a fuel pump going bad, but my pump has always been noisy with no problems. Obviously it is going to be louder when the car is lower in gas as the pump is no longer submerged.
The pump may just be getting louder trying harder to push fuel through a plugged filter, which would also possibly cause surging, that is why I would start with that.
Old Jan 16, 2006 | 05:56 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I would start with a fuel pressure test.
Old Jan 16, 2006 | 10:24 PM
anything-z's Avatar
Car: 86 Iroc
Engine: 87 305 tpi
Transmission: auto
replaced fuel filter and the damn humm is still there. guess i'll try the fuel pressure test next. whats normall for an '86 305 tpi
Old Jan 17, 2006 | 02:39 AM
Spazz698's Avatar
Car: 88 Camaro, 93 civic hatch
Engine: 2.8L, 1.5L VTec
Transmission: 5 Speed, 5 Speed
that hum (which is obvious probably 75% of the time) bothered me and I was concerned the fuel pump may crap out on me eventually but after I talked to a couple other techs at my work both said it's not nearly loud enough to be concerned about. They told me once i can hear the thing humming over my stereo, on a full tank of gas and it sticks around all the time to get worried about it.
Old Jan 17, 2006 | 11:39 AM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
Same here, mine has hummed since I got a new pump 30,000+ miles ago. No trouble yet...
Max
Old Jan 17, 2006 | 05:34 PM
anything-z's Avatar
Car: 86 Iroc
Engine: 87 305 tpi
Transmission: auto
thats cool, i think i'll not worry about it too much just yet. funny thing though, i just installed a couple of 12'' woofers in the back and after a little speaker break in the sound got a little quiter back there, go figure.
Old Jan 17, 2006 | 06:29 PM
vortech35091RS's Avatar
Car: 1991 camaro RS
Engine: 350,vortech heads,zz4 cam,3:73 posi trac,edelbrock carb,wiend stealth intake,raven mufflers,hooker supercomp shorty headers and y-pipe.
Transmission: th700r4
Sounds like a fuel pump is about to go out....Change it before your car leaves you stranded somewhere
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
