MSD ignition boxes
Old Jan 16, 2006 | 08:33 AM
pmpnavt's Avatar
Engine: L98 350
Transmission: 700r-4
MSD ignition boxes
i was thinking about getting an ignition box. the two that i was looking at are the 6al and the digital 6. is there a big difference in the digital 6 compared to an analog?
Old Jan 16, 2006 | 08:58 AM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
get the digi 6 box...you'll be glad you did
Old Jan 16, 2006 | 09:10 AM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
What are the practical advantages of the Digital over the old school? Pardon
my ignorance....
Old Jan 16, 2006 | 11:15 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I changed from a crane hi-6s to a digi. 6+ and love it. Has more "features".
Never used any other MSD boxes, so someone else will have to chime in.
Old Jan 16, 2006 | 01:09 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Digital 6+ has an adjustable 2-step rev limiter included. 6AL requires add-on module & pills.
Old Jan 16, 2006 | 01:25 PM
'Shifter's Avatar
Car: 87 Z-28
What kind of dollar difference are we talking about?
Old Jan 16, 2006 | 02:52 PM
high c's Avatar
Car: 86 iroc
Engine: yea it has one
Transmission: yea it has one of them also (im 2 for 2) :)
installed 6al into friends c4 worked well only bad thing is it hums (installed into glove box)
Old Jan 16, 2006 | 06:31 PM
five7kid's Avatar
Check it out yourself on www.summitracing.com .
Old Jan 16, 2006 | 06:52 PM
pmpnavt's Avatar
Engine: L98 350
ill be a bit more specific...
6al MSD-6420 $229.88
-CD Voltage Output to Coil: 460-480 V
-Spark Output (millijoules): 115 Millijoules
-Timing Retard: None
digital 6 MSD-6520 $309.88
-CD Voltage Output to Coil: 535 V
-Spark Output (millijoules): 135 Millijoules
-Timing Retard: One-stage
are the differences in these two significant? right now my car is running slightly rich, and i was looking for a way to improve the ignition a bit at lower rpm, but later on i dont want to regret buying the cheaper one because it is "so much better" but i dont want to just throw money at summit. (not like i havent already )
thanks again
Old Jan 16, 2006 | 07:45 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If your car is mostly stock there are more effective things you could spend your money on first.
Old Jan 16, 2006 | 07:48 PM
Yeah mine is installed on the right side of the console...and my does buzz also..sometimes loud and sometimes doesnt buzz at all..I called MSD and asked if that was normal and they told me yes..those are the transistors in the box....
this is the best picture I got...I forgot to take one after the complete install...but you cant see any of the wires at all...I installed it there so I had easy access to adjust the rev limit or timing retard for the the nitrous...works damn good..and dont let any tell you its gets hot..cause it doesnt...it get warm...and is far enough away from anyones leg...
on the other side of the console is my MSD digi window switch...again for easy access..whats cool about the digital window switch is its also a digital Tach..which is pretty cool...and that should be dead on cause its running directly from the distributor...so I got my dash tach and digital tach..
Old Jan 16, 2006 | 08:18 PM
pmpnavt's Avatar
Engine: L98 350
did you see any noticable difference once it was installed? besides the timing retard, was it something needed?
Old Jan 16, 2006 | 08:21 PM
pmpnavt's Avatar
Engine: L98 350
my car isnt really stock, i get so tired of typing the mods....need to get the sig working....pic attached
Old Jan 17, 2006 | 07:47 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
What type of ignition are you running now? If your using a non HEI dizzy then I would recommend it, hell, w/ dual 4 barrels and a tunnel ram I'd still bet there would be an improvement.
Old Jan 17, 2006 | 10:18 AM
pmpnavt's Avatar
Engine: L98 350
atm im running an accel dist and coil nothing real special, i will get a box for it but im just not sure which one to order this weekend.
Old Jan 17, 2006 | 12:01 PM
five7kid's Avatar
If you don't need the 2-step rev limiter or timing retard, the 6AL or Crane HI-6 will be fine. Both have a built-in rev limiter.
If you want the 2-step capability, the Digitial 6 is a good part.
Old Jan 17, 2006 | 01:11 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
If you like to bracket race, the 2 step is a great idea. It's helped me out a lot being a manual guy.
Old Jan 17, 2006 | 02:21 PM
pmpnavt's Avatar
Engine: L98 350
so the cd output voltage difference doesnt really matter? except for the 2 step i wont see any other performance gains from it that i would notice?
Old Jan 31, 2006 | 07:19 PM
pmpnavt's Avatar
Engine: L98 350
ttt
Old Feb 2, 2006 | 01:08 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
I was looking at Crane HI-6 not the digital one!
It had revv limiter and timing retard.
I am not sure what stage 2 would do or does for that matter.
The crane HI-6 is 170 bucks at summit.
And check this out.
HI-6 Performance CD Ignition
• Capacitive-Discharge ignition for street
• New HI-6 delivers higher spark-gap current than comparable digital CD ignitions!
• Multi-Spark CD, for race, street, nitrous-oxide, supercharged and turbo
• More HP, torque, crisper throttle response!
• For vehicles with distributor
• New “Plug-n-Go” universal harness included
• New, bigger rotary switches with precise “Click-In” detents for easy rev limit adjustments. No “chips” needed
• Built-in adjustable rev limiter adjusts in 100 RPM increments
• NEW! Easy Checking for System Problems! No guessing!
• Built-in flashing codes tell what the problem is. Checks coil, ground, power supply, loose or broken wires and the ignition unit itself!
• Points, module, mag triggered
• Tach accuracy check feature built in
• Surface-mount, fully digital components
• The most reliable CD ignition available
• Built-in timing retard available with optional Control Module, Part Number 6000-6446
• Fully sealed with new, soft urethane for heat, dirt and moisture protection
• Exclusive Cross-Fire protection, for supercharged or turbo applications
CRANE VS. MSD
CRANE
Crane Cams' ignition has a fully digital design (A Crane 1st since 1995!) For accuracy and absolute reliability! Robotic, surface-mount assembly, same as used in cellular telephones.
MSD
MSD's ignition has low-tech, analog design with hand-soldered, “spaghetti” wires that can break away and cause ignition failure!
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
TrevinE
Sep 14, 2015 03:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
