Spark plug gapping and torque specs needed
Old Jan 17, 2006 | 08:20 PM
MKnight's Avatar
I did a search and alot of people seem to recommend gapping plugs at .035. Recently I purchased a set of Autilite XPPerformance plugs and they are gapped at .045. Is it safe to gap mine at .035 on my 305? I want to achieve the most optimal spark here. Just to let you know, I have brand new MSD distrib with blaster coil and MSD 8.5mm wires.
Also, I have no idea what I'm supposed to torque these plugs to in my engine. I'm trying to do the install tonight so if anyone can help that would be great.
Old Jan 17, 2006 | 08:24 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
with more spark power (bigger coil) you can run a larger gap and get more power. (basically). That's without looking at compression ratio, boost, quality of gas, altitude, etc etc
I think you're not at the time to think about those yet... .045" is a good safe bet.
I've never used a torque wrench for those, just go finger tight plus 1/4 turn or whatever it says on the pack. Depends on the bevel after the threads.
Old Jan 17, 2006 | 08:32 PM
MKnight's Avatar
Thanks for the quick reply. I do want to optimize this as much as possible, what do you think I can increase the gap to without going overboard?
Old Jan 17, 2006 | 08:39 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I ran a factory spec gap on the HVC ignition. That was on my old engine, though...
Old Jan 17, 2006 | 08:46 PM
MKnight's Avatar
If anyone knows the actual torque values, it would be great if you could share. I would prefer to torque these to spec.
Old Jan 18, 2006 | 03:44 AM
MKnight's Avatar
Got all the plugs installed, hand tightened and turned to between 1/4 - 1/2. Car fired up right away and runs even better than before! I love these Autolite XPPerformance plugs.
Old Jan 18, 2006 | 04:51 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
On plug gap according to the Jacob's performance book,and I've tried it,you can try opening up the gap .005" at a time until you feel it flatten out under load.It's trial and error and takes some time,similar to indexing plugs,but it does help.Like Sonix said .045" is safe and that's the rule of thumb on plug tightening,book says 11->15ft/lbs and don't forget the anti-seize.During the '70s factories were using plug gaps up to .065".With the MSD 8.5's and coil you could go .050 to .055 I would feel certain.Just make certain you have full 12vdc running your coil.
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
IROCZ1989
Jan 24, 2016 03:55 PM
db057
Aug 22, 2015 08:17 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
