Questions on 305 heads
Old Jan 18, 2006 | 06:00 PM
joenycfbody's Avatar
Car: 81 Camaro
Engine: 406w/TPI & Serpentine belt setup
Transmission: 700R4 & 3.42 Posi
I have recently acquired a 305 TPI motor from an '88 T/A..
I havent had a chance to pull the valve covers and check the casting #s, but typically, what heads came on this year 305??
If you could give me info like chamber cc's, port volume, valve sizes that would be great.. Also, are these typically thin castings? Or is there enough material to safely port them?
thanks in advance
Old Jan 18, 2006 | 06:05 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
You should have the 081 castings.
I've never messed with a set, so I don't know that much about them, but they are the 87-up versions of the 416 castings. Probably 1.84"/1/5" valves, 58cc chambers. Plenty of meat to port them - just like the 416's.
Old Jan 20, 2006 | 10:19 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
sounds like an LB9 engine that has the 081 heads. They have potential. Keep them and learn how and where to port. Or pay a couple hundred and have someone else do it.
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
