Hard Starting
Old Jan 20, 2006 | 05:12 PM
clewis's Avatar
Car: 1985 IROC-Z
Engine: 305 Tuned Port Injection
Hard Starting
My 85 IROC doesn't start-up right away, like it used to. Now, I have to crank the starter 2 to 3 times for 3 to 5 seconds at a time, before it fires. Sometimes, after firing, it runs really rough and continues up until I stand on the accelerator. After doing so, it usually clears up and runs okay. I'm thinking there's unburnt fuel in the cylinder that's causing this problem. Funny thing is that when it has sat for a couple of days, it fires right up, just like it used to. On one occasion I pulled the number one plug and could smell raw fuel. I replaced the plug, thinking that it was fouled or something, but that has not resolved the problem. Any suggestions would be greatly appreciated.
Old Jan 21, 2006 | 11:14 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
carb? efi?
need more details!
Old Jan 21, 2006 | 01:24 PM
clewis's Avatar
Car: 1985 IROC-Z
1985 IROC-Z, 305 TPI, All Stock
Old Jan 21, 2006 | 02:46 PM
Vader's Avatar
You may have an injector or pressure regulator leakage problem. A fuel pressure test would help reveal those.
It's also remotely possible that the cold start injector or control are the cause, but a pressure test might help indicate those as well.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
