oil guage reads max (past 80)
Old Jan 22, 2006 | 09:10 AM
shawnb's Avatar
Car: 1991 firebird
Engine: 6 cyl.
Transmission: auto
my 1991 bird 6 cyl. runs fine, has a medium oil leak (from where i dont know) but my oil pressure guage reads the maximum, way past 80, is this a sensor problem or am i in big trouble?
Old Jan 22, 2006 | 09:36 AM
grumpyvette's Avatar
if it reads 80 psi most of the time Id suspect the sensor or gauge or the connecting wires are broken or shorted or defective, the oil pump has a bypass circuit that may be jammed but even if that were true, low rpms produce low pressure readings
personally Id replace the sensor and check with a differant gauge, if I still got those reading the pump would get replaced
Old Jan 22, 2006 | 10:07 AM
shawnb's Avatar
Car: 1991 firebird
Engine: 6 cyl.
Transmission: auto
thank you for responding
Old Jan 24, 2006 | 10:45 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
i had the exact same problem. Turned out to be the sending unit......just a few bucks
Old Jan 25, 2006 | 06:17 AM
shawnb's Avatar
Car: 1991 firebird
Engine: 6 cyl.
Transmission: auto
thanks,where is that to replace it?. does the sending unit send the signal to the guage?
Old Jan 25, 2006 | 11:38 AM
1989karr's Avatar
Engine: 3.4 / 5.0
yup. The sending unit is right by the oil filter on the V-6. I think that if you look from above you should be able to see a cylinder looking thing with wries coming out of it. Also, i hear that these things have a tendency to crack and leak some oil when they get old. Perhaps your leak is coming from there?
Old Jan 25, 2006 | 07:28 PM
shawnb's Avatar
Car: 1991 firebird
Engine: 6 cyl.
Transmission: auto
thanks for the info, and thats exactly where my puddle of oil is. i will check it soon.
i appreciate the responces and this site!
Old Jan 25, 2006 | 08:37 PM
high c's Avatar
Car: 86 iroc
Engine: yea it has one
Transmission: yea it has one of them also (im 2 for 2) :)
ive run into this problom 2 times befor....the first time was on a 86 300zx, it read 0 all the time it was the sender and the 2ed was on my brothers turbo honda, it hade a knock and what it was is he spun a crank bearing and just befor the motor died the oil psi shot to 100 and then the oil pump bisted its seals....
Ghettobird52
Jul 5, 2024 11:18 PM
gta90
Sep 15, 2015 04:00 PM
Thornburg
Aug 30, 2015 08:05 AM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
