Solid Lifter for the street...
Old Jan 22, 2006 | 03:18 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
Howdy guys,
I am pondering the idea of a solid cam in my car.
Besides lash adjustment problems, what other complications will there be?
Nothing besides solid flat tappet.
RPM range i'm looking at is 3k-7k...
the heads i am using are ported old, camel hump, heads. they flow quite well, but not really comparable to aftermarket heads, but do get the job done quite well.
What modifacations will have to be done?
I have a brand new set of Roller rockers 1.5ratio, waiting to be installed after my motor is finished.
anyone have any suggestions/comments?
Old Jan 22, 2006 | 04:16 PM
LnealZ28's Avatar
Car: 1987 Z28
Engine: 383 Single Plane EFI-NOW RUNNING!
Axle/Gears: Not there yet...
I think it will be fine for the street, as long as you get the right grind for your combo and, of course, get the springs the cam maker suggests. I'm going to run a solid roller cam in my 383 (see sig) and it will be streetable. Also, modern solid cams are miles ahead of their earlier brethren and lash adjustments shouldn't be a real problem at all.
BTW, remember those old Chrysler slant sixes? They had solid lifters, ran for 300,000 miles and no one ever bothered to adjust their valve lash. VW type 1 motors were also solid lifters, so if two of the most reliable engines ever built had solid lifters, yours can too. My $.02
Old Jan 22, 2006 | 04:52 PM
ede's Avatar
ede
lot of SBCs had solids and ran on the street. lash or resetting it isn't as much an issue as people make it out to be. only thing you might conisder is if it'll have any effect on the knock sensor.
Old Jan 22, 2006 | 05:58 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I have full intentions of running my solid roller engine on the street. Set it up right and you will be fine.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
kkirch15
Sep 30, 2015 04:44 PM
dusterbd
Sep 29, 2015 08:40 AM
