Shopping list for valve seal replacement?
Old Jan 23, 2006 | 04:12 PM
Black_Widdow's Avatar
Car: 05 GTO, 88 GTA, 98 SS
I'm about to change my valve seals. I've never done this type of work before. Actually, I've never even had to pull a valve cover off. I feel confident in my abilities though, and I hope to save some money doing this myself. The car is a 91 Camaro RS, 305 TBI, A4. I would appreciate it if somebody could make a list for me of the things I will need to buy to go the job. Thanks alot
Old Jan 23, 2006 | 05:20 PM
ede's Avatar
ede
valve seals, maybe valve cover gaskets.
Old Jan 23, 2006 | 05:24 PM
ljnowell's Avatar
Basic handtools.
If you are going to use compressed air to hold the valve you will need the adapter to screw into the block. Otherwise you need to make sure you have some rope to use.
Old Jan 23, 2006 | 08:47 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Need one of these to compress the valve spring so you can get the valve "keepers" off.
Attached Thumbnails Shopping list for valve seal replacement?-valvespringcompressor.jpg
Old Jan 23, 2006 | 10:11 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
I would put a fresh set of valve springs on it while they're off. After 15 years and who knows how many miles, they're bound to be tired. Just a stock set will get you by so it wont break the bank.
Old Jan 24, 2006 | 06:43 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
these are the stock replacement springs i used:
http://store.summitracing.com/defaul...981-16&FROM=MG
Old Jan 24, 2006 | 07:56 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
I recommend these seals for both intake and exhaust:
FELPRO SS 72527
http://www.partsamerica.com/ProductD...pe=108&ptset=A
Old Jan 24, 2006 | 08:05 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Probably need one of these to rotate the engine.
http://store.summitracing.com/defaul...-66782&FROM=MG
Old Jan 24, 2006 | 11:43 AM
Thanks to all. Any other suggestions for the list?
Old Jan 24, 2006 | 12:41 PM
91Z28-350's Avatar
Rope or air hold plug.
Rags.
Eye protection.
Valve spring shims so you can lose some weight on the valve train like the splash shield and the rotator on the exhaust valve.
for all the details.
Old Jan 24, 2006 | 11:35 PM
llvll4l2c91350's Avatar
might be a stupid question but, is it possible to do the seals following the firing order of the engine? so no rope or air is necessary but instead the piston being at TDC would keep the valve from dropping?
Old Jan 24, 2006 | 11:45 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
no the valve will still drop into the cylinder a bit because of clearances. You really need to do the compressed air or rope trick honestly.
Old Jan 26, 2006 | 08:56 AM
I will probably go ahead and do a whole valve job. Can somebody recommend a decent set of valves? Thanks again!
Old Jan 26, 2006 | 09:04 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Keep your stock valves unless they are damaged. You will have to pull the head it you want to do a valve job. This will require more time and the cost of head gaskets. Not a big deal really. On a LO3 the compressed air method doesn't work so well. It is hard to get the air line and spark plug fitting into the head with the heads on the car. There is too much stuff in the way. The rope method is easier and is faster. Refer to this thread for some tips on seal replacement on an LO3. You will have to scroll past all the cam stuff first.
LT1 cam digest
Old Jan 27, 2006 | 10:53 PM
MikeS's Avatar
Probably some useful information here if you decide to go through with just a valve stem seal replacment...
https://www.thirdgen.org/techbb2/sho...hreadid=164361
1992 Trans Am
May 10, 2023 07:19 PM
gta90
Sep 15, 2015 04:00 PM
backtothe80s
Sep 5, 2015 12:39 AM
NBrehm
Aug 25, 2015 11:49 PM
