Timing set with cam thrust bearing or not?
Old Jan 26, 2006 | 04:35 PM
91_B4C_RS's Avatar
Car: 1991 B4C Camaro RS
Engine: 370 lsx ls3 heads victor jr w/carb
Transmission: TH400 w/brake coan 8"4500-4800 stal
Axle/Gears: Moser 9" locker w/ 4.11's
i have a 91 z28 with 5.7 tpi. roller cam. was it origionally equiped with a thrust bearing and cam botton? what kind of timing set do i need thanks
Old Jan 26, 2006 | 04:38 PM
No, no thrust bearing or cam button. It just had the regular factory roller setup - a retainer plate.
You need the timing set for 87-up 305/350. Comp 3136 for example.
midge54
Dec 27, 2019 04:14 PM
anesthes
Mar 10, 2016 10:35 PM
camaro71633
Sep 1, 2015 10:24 AM
red90IROCls1
Aug 25, 2015 06:56 AM
gwade12
Aug 8, 2015 08:17 AM
