Pcv?
Old Jan 26, 2006 | 04:37 PM
Demon355's Avatar
Pcv?
Ok, I just bought some kickass edelbrock valve covers off some dude and realized, where the hell does the PCV go? lol! Looking at the pic, bottom cover, the hole on the right thats suppose to be there isn't. Would/could I fix it up that one of the other holes would be used as the pcv? Do I need the pcv? Anything else I could do here? I was going to run breathers in the other holes but was worried about not having a pcv hole, and thought maybe I could run without or get a bigger one for the bigger holes.
Old Jan 26, 2006 | 04:39 PM
transporter's Avatar
Car: 92 Z28
Engine: 305 TPI, Edelbrock headers, 3in Flowmaster exhaust
Nice valve covers. Just drill out the hole, thats all you have to do.
Old Jan 26, 2006 | 04:46 PM
Demon355's Avatar
Thanks. Would running without a PCV hurt the motor?
Old Jan 26, 2006 | 05:07 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I see an oil fill hole, a breather hole and a pcv hole on those VC's, what do you mean?
Old Jan 26, 2006 | 05:10 PM
Demon355's Avatar
well the guy that I bought them off, said the hole thats sealed is the one that was used for the PCV, but he didn't run one so he had it welded up. My question was if I could run a PCV thats bigger than the stock piece and use a existing hole instead of drilling. Or not use a pcv at all.
Old Jan 26, 2006 | 05:49 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
You can get different sized PCV grommets at most parts stores... have a look through there.
Pac J
May 17, 2020 10:44 AM
tyeo098
Nov 30, 2015 06:27 PM
NZKnight
Oct 15, 2015 02:47 PM
sleprock
Sep 24, 2015 04:33 PM
CatmanFS
Sep 19, 2015 09:00 AM
