Rod or Main Spun Questions
Old Jan 27, 2006 | 01:58 PM
kileschilke4's Avatar
Car: Firebird 1987
Engine: 350 sbc chevy
Transmission: Turbo 350
i spun either a rod or a main bearing i am hoping its a main bearing cause i was told that i might not have to tear down the whole engine if it is and just the bottom end would have to come out....but if it is infact a rod would you pull the whole engine apart my time is limited i'm doing this at my college course but i could pry have it there a week or two...hit me up with ideas
Old Jan 27, 2006 | 03:16 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
It is possible to change the crank & bearings with engine in the car. I have done it myself.
Old Jan 27, 2006 | 03:28 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
While it may be possible, it will be much easier to just pull the engine out and put it on a stand. Also much less potential damage to parts. Infact, I don't see how you could install a crankshaft properly upside down. Plus, you can do more with the engine out (regasket everything) with less time.
I'd recommend pulling the engine and doing a full inspection.
Old Jan 27, 2006 | 04:00 PM
Ricktpi's Avatar
What makes upside down so hard other than fighting gravity? I would recomend pulling the engine too. Like I said I have done it as have many techs I have worked with over the years. Flat rate techs find some creative ways to do repairs.
Old Jan 27, 2006 | 04:01 PM
ede's Avatar
ede
if you spun a main your crank and block are trash if you spun a rod bearing then only the rod and crank are trashed. either way you need to take everything apart and have it cleaned and replace the bearing, rings, etc.
Reborn756
Sep 4, 2015 03:42 AM
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
redmaroz
Aug 16, 2015 11:40 PM
