Manual Steering and Brakes?????
Old Jan 27, 2006 | 03:02 PM
ndamron's Avatar
Car: 82 Trans-Am / 83 Trans-Am
Engine: Major Mod SBC / Minor Mod SBC
Transmission: Major Overhaul 700R4 / Stock 700R4
Axle/Gears: None!!! / 3.73 posi disc...soon
Did third gens ever come with manual steering and brakes??
Does anyone know what manual steering boxes and barke cyclinders would be compatible with my 82 T/A??
Thanks all!!
~Nick~
Old Jan 27, 2006 | 03:11 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
A manual box from a S10 truck will work. Why you would want manual brake is beyond me.
Old Jan 27, 2006 | 08:07 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
To answer your question, no.
I use a manual steering box from an S10. My manual brake master cylinder is also from an S10 but it's far from being a direct bolt in. Fabrication and modifications are required.
The manual steering is good especially for a drag car. There's a huge weight saving from removing all the power steering stuff.
Converting to manual brakes only has one advantage. More room in the engine compartment. The brake booster is only about 5 pounds.
Old Jan 27, 2006 | 08:11 PM
ndamron's Avatar
Thanks a lot for your help!
~Nick~
Old Jan 28, 2006 | 08:50 AM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
I am using the same stuff as Stephen87,
In my case I used the box and pitman arm from the S-10,and it still drives great,no problems whatsoever.And my car is still street driven.
But unless you just don't have any vacume for power brakes,I'd stay with them.The booster truly is light,as mentioned above,and I know if I had the vacume to operate them,I'd go back in a second.
If you have to have manual brakes,A buddy of mine swapped in a master cyl. from a Vette w/ 4 wheel discs into his V8 S10,and his brakes are notically more responsive than mine.
I'm considering changing over to it myself,if it works on his S10,and an S10 master can be made to work on a 3rd gen,it should be doable.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
deracer
Apr 11, 2016 12:04 AM
backtothe80s
Sep 5, 2015 12:39 AM
kyleb24
Aug 15, 2015 08:24 AM
