LG4 idling issues
Old Jan 27, 2006 | 07:32 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
LG4 idling issues
not for my car, but my best friends monte carlo. The thing has issues where it will seem to accelerate nicely from a stop or at most times, however, sometimes when you drop the hammer, the thing coughs and sputters like it doesnt wanna go anywhere. WE adjusted the TV cable twice, and have it set pretty well, but that didn't get things fixed right. Car also has a fresh tuneup. The car has more recently began having an idling issue. At 1000 rpm the car will idle fine and smooth, however, if the idle comes down to between 500-600 rpm, the car starts sputtering like it doesn't really want to run.
Vehicle only has 44,000 miles on it, but, its' having isues like it has 144,000, can anyone give some insight to these problems? Thanks in advance.
Old Jan 27, 2006 | 11:42 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Did the "fresh tune-up" also include a carburetor rebuild? Even with 44,000 miles it needs to be periodically gone through due to lack of use.
The throttle shaft bushings are known to wear out quickly on those carbs too. That will allow excess air into the intake and can cause idle and driveability problems.
Old Jan 28, 2006 | 12:31 PM
85f-bird's Avatar
Engine: 2.8L, LS1
Didn't include that, thanks for the info....i'll pass it along, any more ideas?
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
bamaboy0323
Sep 3, 2015 06:07 AM
mike_c
Aug 27, 2015 04:32 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
