Rod nut torque with ARP bolts
Old Jan 27, 2006 | 08:30 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
I am finally assembling a .030" over 400 smallblock with parts I bought two years ago.
I have Scat forged 6" rods with ARP studs and nuts, but I no longer have the packaging the rods came in.
My question concerns the torque- When I used my ARP main studs they had a spec for torque using their moly paste and a different spec using 30wt oil on the threads.
My question is what is the advised torque on these using ARP's moly paste? I have also read how the rod bolt stretch method is best, but I'm not buying the gauge to measure that to just build one engine.
Old Jan 27, 2006 | 10:35 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
The info you need can be found here
ARP site
Old Jan 28, 2006 | 12:03 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
My machine shop torque my 2 bolt main studs to 70lbs. After looking at the site above, he was right on the money. If you have a 4 bolt main, the inner botls are 70 while the outer bolts are 65
Old Jan 28, 2006 | 01:59 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Rod bolts man, not main cap bolts
Old Jan 28, 2006 | 08:24 AM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Please don't torque your rod bolts to 70 ft/lbs
Old Jan 28, 2006 | 03:05 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Ahh yes. lol.
Frozer!!!
Jan 19, 2024 04:55 PM
355tpipickup
Aug 25, 2015 12:54 AM
Navy8125
Aug 22, 2015 07:13 PM
LT1Formula
Aug 20, 2015 09:36 PM
