dd2000 head flow file question
Old Jan 27, 2006 | 11:48 PM
blackgold84's Avatar
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
on dd2000, i see people with screen shots of their heads listed in the head flow slot, how-where do i get these on line and are they close to real? id like to put mine in there instead of stock with big valves and porting...
-doug
Old Jan 28, 2006 | 12:57 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
people usually get their flow charts online from somewhere.. and then input them into the program. the program does not calculate your flow.
Old Jan 28, 2006 | 09:32 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I made my head flow file right in DD2000 using the numbers off the flowchart that my shop handed me after flowing them
Old Jan 28, 2006 | 10:46 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Head flow #'s
Try here:
http://chevyhiperformance.com/techarticles/41598/
Old Jan 28, 2006 | 09:35 PM
lilbowilson's Avatar
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
Blackgold so tell me how you like the voodoo cam? I was thinking about getting that same one. Can you really feel a differences with it?
Old Jan 30, 2006 | 08:09 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
People need to stop posting that BS, and start posting RWHP dyno sheets...
Old Jan 30, 2006 | 08:36 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
C'mon Brody
DD is a good tool to estimate what a combo may produce. You can't dyno a ton of combos back to back as easily as you can with a few clicks of the mouse. DD allows you to dial in a good combo before you go to the dnyo to validate it. DD is a good way to graps performance trends with certian grinds of cams and head styles. It can save you a lot of money in the long run and help you reach a specific power goal.
Old Jan 31, 2006 | 11:55 AM
TexasLT1's Avatar
Car: '92 RS
right, because so many people post DD numbers instead of real dyno numbers. relax. its just another tool to use in the engine building process.
Old Feb 3, 2006 | 08:03 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
DD is a great tool for seeing how a particular combo will work as stated, it's a great tool for seeing power curves and how certian changes affect it.
I will say that I wish they had more real world specs like for my 416 heads.
However, DD is just math. You can not argue against math, there is no way. DD has outrageous numbers because they are being calculated assuming a 100% perfect condition, no power robbing acessories, all setup and tuned perfectly, etc.
Math is math, dont fight it. DD is not real world however, so I wish people would stop using it in place of a real dyno.
Does anyone know where to get DD spec files? I dont know enough to fill in all the info myself
Old Feb 5, 2006 | 08:32 AM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
Originally posted by 88_Import_Slaye
..... I will say that I wish they had more real world specs like for my 416 heads.
Go here and look for the 081/416 links, both stock and ported.
89fast5oh
Sep 27, 2015 09:04 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
