Oil pressure guage
Car: 1991 GTA
Oil pressure guage
Where do I connect my aftermarket mechanical oil pressure guage in my 91 gta?
Car: 1991 GTA
Is the arrow pointing at the front of the block just below the intake left side? Is it a plug? If it is then it must be behind the AC bracket.
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Correct. You may have to remove the sensor above it for access. It's still easier than on the back of the engine under the distributor.
