Partial AIR removal
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
Partial AIR removal
I live in PA and I have inspections.
I also have a dual snorkel air cleaner patiently waiting to go on. The AIR junk is in the way.
Can I (read: has anyone ever) remove enough of the AIR system to fit the dual snorkel, and plug vacuum lines and such, so that when inspection comes around I can put the stock stuff back?
Any problems with partially removing the AIR?
There is no conflict between AIR and dual-snorkel air cleaners.
The L69 cars were equipped with AIR, same as any others of the time.
No need for this pretext to hack stuff off your car. Just put the air cleaner on.
Car: 91 RS, 95 Z28
Have you put an L69 air cleaner on a 91 TBI?
I did.
I took off my stock air cleaner, and put the Dual snorkel on top of the TB. It tilts about 4 inches in the air on the left side because it sits on top of the AIR diverter box and hoses.
If you found a way around it, let me know, otherwise, has anyone partially removed the AIR. Any complications (such as vacuum, Cat. issues)?
I did.
Car: 91 RS, 95 Z28
This is a post of someone else with the same issue:
Here is what I was looking for.
Car: 91 RS, 95 Z28
More answers in this post (I'm posting these in case some one else ever needs it):
Answers
Answers
