Short water pump with stock v-belt setup?
Old Feb 3, 2006 | 10:13 AM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
I have a Monza that requires a short water pump (corvette style pump) in order to fit behind the radiator.
The engine I've got is all stock accessories and brackets from a 75 truck (350 ci).
With a stock water pump all pulleys line up with the alternator, crank, and water pump perfectly. But now that I put in a short water pump I can't find a pulley that lines up with the stock belts.
Have any of you guys tried to run a short water pump with the stock vbelt setup? What pulley did you use?
BTW converting to a corvette accessory system is out of the question for me because I am running a motor plate.
Any suggestions would be great. thanks
Old Feb 3, 2006 | 10:20 AM
stitchop's Avatar
Car: 91 firebird
A custom aftermarket pulley that works with your set up will cost more than you could buy the short accessory system from a junk yard.
eightsixseven
Dec 16, 2024 01:50 PM
theshackle
Mar 5, 2017 06:37 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
