Serious Engine Hesitation
Car: 88 iroc
Engine: 350 tuned port
Transmission: tremec 6 speed
I'm looking for some help,here's the story. I start the car and let her run until it's warm. When I give it a stab at the throttle it chokes out and if i keep the pedal down it will stall. However if i raze the Rs slowly i can bring it up to redline.what's the problem. The car has been sitting for a while but it has water remover in the tank and i ran and injector cleaner for good measure. I replaced the feul pump a while back so i know thats still good. New coil and air filters.
Has anyone had this problem. I would greatly appreciate some sound advice. Thanks
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Checked fuel pressure at the regulator? Normally a no-rev is associated more with low fuel pressure/fuel starvation. Fuel filter fixed this problem on my buddy's old Bronco, it was the original filter and finally clogged. Although it took about 15-20 minutes of running to clear up, the filter itself came apart and I believe sent pieces of debris into the lines and was plugging up the rail and injectors.
Car: 1991 RS
Engine: 90' TPI 305
Axle/Gears: posi disc 3.23's
this sounds like a problem im having exactly. except mine happened over night. is that possible still for the filter to be clogged?
