thrust bearing
Old Feb 5, 2006 | 02:09 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
thrust bearing
dumb question, where does the thrust bearing for the cam go? between the retainer and the gear drive, or the retainer and the cam?
Old Feb 5, 2006 | 02:32 AM
Vader's Avatar
Are you adding a Torrington roller thrust bearing, or asking about a shim type bearing?
Old Feb 5, 2006 | 02:37 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
just the copper shim bearing.
what is this torrington bearing?
Old Feb 5, 2006 | 12:05 PM
Vader's Avatar
ON the older design blocks (non-roller) you can install a timing set with a roller thrust bearing to minimize friction from the axial loading of the cam. I have not seen one of these for a roller block. A plain bronze washer would be fit between the retainer and rear of the cam sprocket to take up the thrust loading from the cam trying to pull itself into the engine as a result of driving the oil pump and distributor. You may have to machine the rear face of the cam sprocket to provide clearance.
Old Feb 5, 2006 | 01:25 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
oh hmm.. weird, because when i pulled my set apart on my roller block i had one thier, forgot where it went, thats why i asked..
so i dont even need it?
Old Feb 5, 2006 | 04:09 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
If it's the same gear drive you'd want it between the cam drive and the retainer.
The rear of the cam drive would make it's presence known on the retainer (wear it away) more-so than the cam on the retainer.
It may have been there to straighten out the alignment for some odd reason or another.
gord327
Oct 3, 2015 01:25 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
mfp189
Sep 27, 2015 09:25 AM
brockerboy
Wheels and Tires
Sep 17, 2015 03:59 PM
