Bad smog pump?
Old Feb 5, 2006 | 09:16 PM
Phyte's Avatar
Car: 92 Z28
Engine: 350tpi
Bad ps pump?
I've got a "whining" sound coming from the front of the engine, and also a light "tick" that can only be heard from inside the car. The two started at the same time. The ticking goes away when you rev the engine above 800rpm. More then likely a bad pump huh. Stock 92 L98 motor with 61,000 miles.
Phyte
EDIT: Just noticed I put smog pump in the title.. opps! Meant power steering.
Old Feb 7, 2006 | 05:12 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Power steering pumps will whine when they are low on fluid. Hard to say what the ticking sound is. Could be a lot of things. You could try starting eng with power steering belt removed.
Old Feb 7, 2006 | 05:16 PM
Phyte's Avatar
Car: 92 Z28
Engine: 350tpi
Ok the whine was a bad idler pulley. I think the tick is either an exhaust leak or spark knock. It wasn't knocking on saturday when I bought it, and the only thing I did was put some gas in it.. 87 octance(habit). I'll put a little 91 in it and see if it goes away.
Phyte
Old Feb 7, 2006 | 05:18 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
today I noticed a rattle near the top end of the engine, sounded like a rocker was loose or a spring broke and made the valvetrain rattle.
Pulled teh valve cover and everything looked good, started up the car and valvetrain was moving properly, but that noise was still there.
Put my hand over the opening on the back of the smog pump and the noise quieted down.
tomorrow i'll yank the pump and get a shorter belt.
Glowsock
Jul 24, 2025 03:15 PM
italiano67
Dec 11, 2016 09:21 AM
xxx3man`
Sep 23, 2015 10:37 PM
backtothe80s
Sep 5, 2015 12:39 AM
Winchester1094
Aug 18, 2015 10:23 AM
