fuel pump wont stop running
Old Feb 6, 2006 | 03:57 PM
all spooled up's Avatar
Car: 89 IROC-Z / Turbo Grand Prix
Engine: 406 MPFI / 3.1 intercooled turbo
Transmission: 700r4 / HM282 5 speed
Axle/Gears: 4.10 / 3.91
Hey guys.Been messin with my buddys 89 IROC-Z.We replaced the motor and now the fuel pump wont stop running.Even with the key in the off position.If I pull the ECM fuse(passenger side radiator support)the pump will shut off.I have checked all grounds and changed the FPR.He is also running a holley stealth ram but it was on the previous engine.I have done some searches but no luck there.Any help would be appreciated.Later
Old Feb 6, 2006 | 04:03 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Well if I were you I'd put a couple spades into the fuse, run an inline fuse, and a switch... But yeah I realize you wanna do it *right*...lol wish I could help. But for whatever reason, the fuel pump is getting power constantly so check all the wiring all the way back. Its going through the fuse panel since the fuse will kill it, but somewhere along the way it's getting a direct feed and bypassing the ignition column.
Old Feb 6, 2006 | 04:18 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Pull the plug off the oil press switch located just above the oil filter. This switch powers the fuel pump and they occasionally stick in the closed position.
If pump still continues to run, try swapping the fuel pump relay with one of the other relays next to it (MAF power & MAF burn-off relays). The relay may be stuck in the closed position.
Old Feb 6, 2006 | 04:23 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
This thread has a schematic to help troubleshoot.
https://www.thirdgen.org/techbb2/sho...hreadid=342980
Old Feb 7, 2006 | 02:41 PM
Oil pressure sending unit bad.Never would of thought that.Thanks guys Later
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
