'89+ A.I.R. delete belt length?
Old Feb 7, 2006 | 11:13 AM
esc's Avatar
esc
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
I did a search and found a bunch of info, but no conclusive answer to my question.
I am about to install a serpentine system from an '89 RS on to my '82. I will not be using the AIR pump or an idler pulley.
Using the otherwise origional routing, what length belt will I need?
Old Feb 7, 2006 | 12:03 PM
WoostahGTA's Avatar
Car: 1990 Trans AM GTA
Not sure, but if no one answers, here is some advice someone gave me. Use a piece of string or something and run it through the way you plan on running your belt. Afterwards, measure the string, this will get you a good estimate of what you need. Buy a belt(make sure you can return it if it doesn't fit) close to the length of the string and see if it fits, and go from there. Might take a couple visits to the autoparts store, but should work.
Old Feb 7, 2006 | 12:32 PM
stitchop's Avatar
Car: 91 firebird
I do not understand how you will be able to tighten the belt without the idler pulley as the idler is spring loaded and is what a serpentine system uses to keep tension on the belt. The accessories do not have adjustments to tighten the belt, as in V-belt drives.
Old Feb 7, 2006 | 12:53 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
What I meant is that I will not be replacing the AIR pump with an idler pully. The tensioner will remain intact.
Old Feb 7, 2006 | 01:02 PM
stitchop's Avatar
Car: 91 firebird
then that will work, sorry for the confusion
Do the string method if nobody has a quick answer
Old Feb 7, 2006 | 01:08 PM
esc's Avatar
esc
Engine: 377
Transmission: 400
No problem, I guess my first description was a little confusing.
Anyway, if no one knows (I hope someone does) then I will use the string method and post my results.
But I'm still hoping that someone else who had to make 4 trips to the parts store will remember and save me the trouble.
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
