enigne stumbles
Old Feb 10, 2006 | 03:05 PM
linkz761's Avatar
Car: '86 Trans Am
Engine: stout 350
Transmission: automatic
enigne stumbles
ive been playing with my car after the rebuild, and when i get on it from a stop it stumbles, falls flat on its face, and then kinda remembers what it was doing and is fine, better than fine. After it makes it outta first gear it flies. anyway, would anyone have a suggestion as to why it would stumble like that?
Old Feb 10, 2006 | 03:18 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
It could be numerous problems, but we will need a better description... Does it actually bog down?? I sounds to me like a fuel/ignition problem, but very hard to pinpoint with the description you have given us...
Old Feb 10, 2006 | 05:09 PM
linkz761's Avatar
Car: '86 Trans Am
Engine: stout 350
sorry
sorry not too good at describing things. Ummmm, Lets see, ill wait till my car gets to idle, then ill gun it. Itll start to rev like it should but then it sounds like its at like 1/4 throttle, then itll pick up again right before it shifts to 2nd gear. hope that helps a bit
Old Feb 11, 2006 | 12:13 AM
old88sub's Avatar
This might give you an idea where to look.
http://www.goingfaster.com/spo/elect...ement_sys.html
Old Feb 11, 2006 | 12:22 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Have you verified the accelerator pump operation??
Old Feb 11, 2006 | 10:24 AM
linkz761's Avatar
Car: '86 Trans Am
Engine: stout 350
accelerator pump?
wheres the accelerator pump and how would i check if its working right?
Old Feb 12, 2006 | 06:41 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
It's inside the carb.
To verify ops, remove air cleaner so you can see down the front bores of the carb. Shine a bright light in there. Rapidly open the throttle (this is with eng off) and look for a good squirt of fuel into the bores of the carb.
When the throttle is opened rapidly, the eng sucks in a bunch of air. You need a squirt of fuel to keep the air/fuel mixture correct during this transition.
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Logan Bryant
Sep 23, 2015 06:51 AM
RedLeader289
Sep 23, 2015 06:50 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
