Neg. backpressure and code 32 ?
Old Feb 11, 2006 | 05:35 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Anybody have problems with code 32 after installing 3" cat back exaust? My 88 305 TBI has a 3" c/b with a gutted cat and was wondering if the low back pressure was causing the EGR valve to operate in open loop. After monitoring a vacuum gauge while driving I noticed that while in open loop, the EGR valve is operating at all RPM's.
I was under the impression that the ECM grounded the control solinoid and didn't allow EGR operation untill the engine reached operating temp. and went into closed loop.
The problem is, when the engine goes into closed loop or close to it (according to my temp. gauge) the ECM tries to ground the EGR solinoid and cut off EGR operation. About 180* it cuts off EGR vacuum for 3 seconds and comes right back on. It will do this twice in about 10 sec. causing the SES light to come on and register code 32. I know I have the negative backpressure EGR valve and maybe the cat back was causing problems with the operation.
After the SES light comes on, it will stay on if I'm on the interstate untill I exit and stop and go a couple of times or, I pull over and shut it off and restart it and it will stay off.
After the engine warms up EGR operation is normal. All EGR componants are new and passages are clear. What drives me nuts, is the SES light being on and the fact that being emissions related the ECM is retarding my EST so I'm not going to get the max amount of spark advance and therfore fuel milage and power
will suffer.
Any suggestions? Anybody else having this problem? What can I do short of sticking a potato in one of my exaust pipes to increase backpressure. I've thought about installing a smaller orfice in the EGR valve but I'm not sure if that will accomplish anything but if I can't find any info I guess experimentation plus trial and error is my last resort~!
Old Mar 2, 2006 | 01:03 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Gee, 20 views and no posts! Whats up? I figured even a moderator would have jumped on this one!
Old Mar 2, 2006 | 09:28 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
well to at least give you a post in here.
I have no idea but hope someone can help out soon enough
Old Mar 2, 2006 | 09:59 AM
contact's Avatar
Engine: sbc 350
I vote for the potato.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
