83 camaro ticking
Old Feb 11, 2006 | 09:11 PM
RST89's Avatar
Car: 1983 camaro
Engine: 2.8...... 3.8t coming soon or should I do a ls6 almost the same cost hmmm.....
Transmission: 3spd soon to be either a 700 or t56....
83 camaro ticking
ok i have a 83 camaro 2.8 2bl carbed. i hear this ticking coming from my engine bay i dont know what it is i found it . in the front on the drivers side of the engine bay there is a vacume canister and next to it a circulat thing that kinda looks like an accordian when i push it togeather the idle goes up and then of course it goes back out. what is that and should it be ticking?? Thanks in advance
Old Feb 11, 2006 | 10:54 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Well, the most common reason for a 'ticking' sound in the engine bay is an exhaust manifold, or an exhaust header that is not bolted down tight to the heads. When this happens, gas escapes after each fire of the cylinder, so you get a small 'tick' each time a cylinder on that side of the engine fires. This is remedied by getting the engine nice and warm and then torquing those studs back down, and if that doesnt work, you have to get new gaskets and then use some copper sealant to make sure you get a nice permanent seal.
But, in your case, I am kind of confused, because your explanation was not quite clear. Is the ticking coming from that circular 'accordian' thing, or not, and if you can provide pictures of what you are talking about, that would be even better.
_Clark
Old Feb 12, 2006 | 06:52 AM
RST89's Avatar
Car: 1983 camaro
yes
yes it is coming from the circular thing i can almost feel it when i touch it and when i press it togeather the idle goes up and the ticking stops ill get some pics up
Old Feb 12, 2006 | 09:54 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
The accordion-looking piece is the servo control for your cruise.The reason your idle goes up when you push on it is your pushing on the cruise's throttle cable connection.The canoster next to it the Evap charcoal canister for the emissions system.Like Guitar stated the most common causes for a tick sound is an exhaust leak.Do you hear it less or mor as the car warms up.Also the tick can come from a lifter or something simple as low oil level(well simple if you catch it complicated if you run it to low obviously).
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
redmaroz
Aug 16, 2015 11:40 PM
mustangman65_79
Aug 7, 2015 09:55 PM
