Need Help ASAP- Jerking, Losing Power, Noise
Old Feb 14, 2006 | 07:57 AM
uGOgirl's Avatar
Car: 87 Firebird
I have an 87 firebird (305). It's been running pretty well except for disliking the cold. This moring I let it warm up like I always do but when I started out, the car began jerking like I was letting off the gas and flooring it and letting off again immediately.
It has done that a little when I don't let it warm up enough but this didn't get any better. There was also a noise like a small pop (almost like a small backfire sound) under the hood as this was happening. It is really bad when I take off but if I can get up to about 2nd gear and keep the speed steady, it pretty much stops.
Can anyone tell me what might be going on? I've only had this car a few months and I'm doing my best to learn as much as I can but I'm really a novice. Haven't done too much with it except for changing the spark plugs, wires, distributor, and rotor a few weeks ago. (Didn't get the 2 plugs that are hardest to reach yet.)
Old Feb 14, 2006 | 09:46 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
For the back two plugs, go from underneath the car. You might actually be able to see them....
Check your timing. I suspect that it is off.
theshackle
Sep 17, 2020 08:26 AM
xxx3man`
Sep 23, 2015 10:37 PM
formula_novice
Sep 5, 2015 03:58 AM
B_Dubya
Aug 26, 2015 05:09 PM
sailtexas186548
Aug 24, 2015 10:11 PM
