350 heads?
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 5 spd
Axle/Gears: what ever stock is
so i see that it says 1.94/1.5 valves and its for 305-350. but is it the same as one a regular 350? found some heads for cheap, just want to make sure that they're worth the time and effort over my stock 305 heads.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
They are primarily 350 TBI heads. Stock for stock you probably aren't gaining that much other than a slight drop in compression.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
As Stekman said, they are basically the same head as you currently have on your car now (187's) but they have larger valves (1.94/1.5 x 1.84/1.5 and chamber size (64cc vs 58). There is no need to swap to them. They were used on a multitude of LO5 (350 TBI) motors. This includes trucks, b-bodies, and vans.
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
