350 heads on a 305
Old Feb 16, 2006 | 06:49 AM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
350 heads on a 305
curious to know if i could try to us an aluminum 350 head with the smaller chambers and 1.94 valves on a 305. will the valves clear the smaller bore? i know world makes an iron 305 head, but i want the lighter aluminum.
Old Feb 16, 2006 | 09:09 AM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
yah it would work fine, just use 350 head gaskets with the heads.
Old Feb 16, 2006 | 03:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Your effective compression will be lower, even though the static compression will be about the same as with the iron 305 heads.
Basic bowl work/pocket porting would probably make up for the loss in compression.
Old Feb 16, 2006 | 05:02 PM
wdigitog's Avatar
would the compression be lower even with 58cc chambers?
Old Feb 16, 2006 | 08:44 PM
five7kid's Avatar
Aluminum transfers heat more rapidly than iron. Heat = energy, so the energy lost from heat transfer would mean less energy to drive the piston down. So, to make up the lost energy, the static compression is raised to regain the power.
An iron-headed L98 has 64cc chambers for a 9.3:1 static compression ratio. The same L98 with aluminum heads has 58cc chambers for 10:1 static compression ratio. Same power, no problems with pinging, etc., etc., etc.
For a 305 to have the same power potential (all other things being equal) with aluminum heads as it does with iron heads, you need a higher compression ratio with the aluminum heads than you do with the cast iron heads.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
st.evel07
Aug 13, 2015 06:15 PM
