rotor removal.
Old Feb 16, 2006 | 01:53 PM
sgt0704's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 5 spd
Axle/Gears: what ever stock is
rotor removal.
so i'm in the process of changing my cap and rotor. i got to the rotor, and i cant pull it off. in the book it says there's two bolts holding it down, but i don't see them. the msd one i have, looks like it would just pull off. do i just need to put more force on the old ****, or is there more to it?
Old Feb 16, 2006 | 01:57 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It pulls right off. They can be hard to get off if they have been there awhile.
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Which dizzy do you have? External coil or coil in cap? If you have external coil dizzy, you just pull up like hell on the rotor and it will pull off the shaft. Coil in cap dizzy the rotor is mounted with 2 screws clearly visible.
My car has the external coil dizzy and I usually just get the Accel cap and rotor package at the local Kragens. Works fine, never a problem.
Fanatic1074
Oct 3, 2022 05:57 AM
loud91rs
Oct 5, 2015 10:05 PM
the_hamturdler
Sep 30, 2015 12:50 PM
the_hamturdler
Sep 22, 2015 02:59 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
