Lunati cam instead of XE274 ?
Old Feb 23, 2006 | 02:09 AM
fin170703's Avatar
Car: '87 iroc camaro
Engine: 350 L98
Transmission: 700-R4
Axle/Gears: 3.27 posi
So i'm about to order all my parts up , thanks for the help selecting them ,including a XE 274 cam and i see on ebay that a guy living close to me is selling the following kit
http://cgi.ebay.co.uk/SMALL-BLOCK-CH...QQcmdZViewItem
Now living in the U.K parts rarely come up on ebay so it might be a good buy.
Any of you guys used this cam before ? its to go in a 350 with forged pistons / connecting rods , block bored .030" over , crank ground .010" under. I will be using the edelbrock RPM heads so the cam lift wont be a problem. Loopy idle is also not a problem
Many thanks. Craig
Old Feb 23, 2006 | 02:20 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Not the same. This Lunati cam is quite a bit bigger.
more intended for a high compression ratio drag or circle track motor running a single plane intake and open headers.
Very rough idle, very low manifold vaccuum. Pass.
Old Feb 23, 2006 | 02:23 AM
fin170703's Avatar
Engine: 350 L98
Yeah i think ya right . Maybe a bit to aggresive for me .
XE274 it is then.
Cheers mate
Old Feb 23, 2006 | 02:28 AM
F-BIRD'88's Avatar
email the seller and have him clarify the actual cam part number or grind number.
if it is Lunati number 00012 these are the specs.
HYDRAULIC, Fair idle. Good street street/strip cam. Needs headers, gear and converter. 2500-6500 300°
300° 246°
246° .515"
.515" .343"
.343" 108° Sep
104° Int C/L 19°BTC 47°ABC /
55°BBC 11°BTC 00012 00012LK HYD
it is simular to Comp Cams 292H magnum
it is a good step more radical than the XE274H
Definatly needs a high 3500rpm stall converter, and 4.10's
use with 10:1 + compression and a 750 with a Vic JR intake.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
john204481
Sep 7, 2015 03:22 PM
