form-a-gasket or gaskets?
Old Feb 23, 2006 | 09:35 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I am finishing building another engine and am wondering if for the Fuel pump block-off, water pump and timing cover if it is better to use some of the red RTV sealant or the black gaskets that you always get.
I would think that the RTV would seal better, but would it be as good? I have both.
Old Feb 23, 2006 | 10:10 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
I use a very thin coat of RTV on both sides of the gaskets and seems to seal up good.
Old Feb 23, 2006 | 11:09 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I use spray Coppercoat on paper gaskets & surfaces.
Old Feb 23, 2006 | 11:49 AM
ede's Avatar
ede
i like a very thin layer of untracopper on all pans then the gasket and depending where i might use high tack to hold the gasket to a machined surface. like 1 piece oil pan gaskets and they get no sealer of any sort.
Old Feb 23, 2006 | 01:51 PM
Tibo's Avatar
Car: 1991 Z28 Vert
So I guess that the answer is to use both.
Old Feb 23, 2006 | 02:09 PM
five7kid's Avatar
I wouldn't put RTV on a gasket, personally.
db057
Jan 10, 2020 08:55 PM
sheachopper
Jul 31, 2019 11:27 AM
TP355Z
Exterior Parts Wanted
Oct 21, 2015 01:05 AM
Jonas Earl
Sep 27, 2015 07:39 AM
hdis2002
Sep 8, 2015 02:52 PM
