yet another starter problem
Old Feb 23, 2006 | 04:05 PM
drdroopy's Avatar
Car: 1991 Firebird
Engine: 3.1 V6
every time i try and start my car (91 Bird, v-6) the starter turns but wont catch every time, after 4-5 trys, usually (sometimes more), it catches and turns over, the starter is less then 5 months old and i have tried 2 selenoids, when i first put new selenoid in it worked pretty good for about a week, then went back to the way it was acting b4 i got it, have also tryed with and without shims, not much of a difference, any suggestions????
Old Feb 23, 2006 | 08:57 PM
zimmchile7's Avatar
Car: 1985 Trans Am
Engine: 383 Stroker
sounds like the bendix is stuck. try spraying it with silicone spray and moving it by hand. (bandix is the gear in the starter that engages with the fly wheel.) happens all the time on cessna's.
Old Feb 23, 2006 | 09:17 PM
llvll4l2c91350's Avatar
check the teeth on the starter and flywheel
Spyder_TheGamer
Dec 25, 2015 05:07 PM
5spdcamaro
Aug 28, 2015 02:12 AM
92camaroJoe
Aug 13, 2015 06:07 AM
milk
Aug 10, 2015 06:26 PM
