Ignition module replacement
Old Feb 24, 2006 | 04:49 AM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Yo guys, I think the 8 pin module in my dizzy has seen it's better days. Can it be replaced with the diz still in the engine, or do I have to pull it? TIA.
Old Feb 24, 2006 | 06:47 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
No need to pull out the Dizzy. If you disconnect the spark plug wires be sure to label them.
teapot3208's Avatar
Car: 1985 Camaro
Engine: 350 .030 over (355)
Transmission: 700-R4
NVM, I was thinking on my car, oops.
Old Feb 24, 2006 | 07:03 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
It can be done in the car. Be sure to use new silicone paste that is included with most replacement modules.
Old Feb 24, 2006 | 03:25 PM
Tremo's Avatar
Thanks for the info guys, glad to hear I don't have to pull the dizzy.
Yeah, I know about the silicone heatsink compound. Actually, I'll use some of the silver-loaded heatsink grease I use for computer CPU heatsinking since it conducts heat better than the plain stuff.
But what about the module itself? A new Delco D1990 module costs like $80 or so from the local dealer. I can get a new Pertronix module from Summit for under $50. Will the Pertronix module last?
TIA.
Old Mar 10, 2006 | 01:14 PM
Tremo's Avatar
Thanks guys. the new module was indeed the fix for my cutting-out problem. I put in a new Pertronix D2002 module, fired it up and took a drive. No more problems, I guess the old stock module had sparked it's last. And yes, replacement of the module with the diz in the car was no problem at all. Instead of the clear silicone gel that Pertronix supplied, I instead used Artic Silver heatsink compound, which has higher thermal conductivity, it's used on computer CPUs between the chip and the heatsink/fan. Anyway, thanks again to the experts on TGO to help me solve the problem with my motor.
Old Mar 11, 2006 | 12:10 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
wow.. the module for my accel distributor was 15 bucks at autozone
Ghettobird52
Jul 5, 2024 11:18 PM
db057
Aug 22, 2015 08:17 PM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
