OK when my car comes out in the spring i'm gonna make the switch from pennzoil dino oil to mobil 1 synthetic. Since ive had the car, my dad has changed the oil 3 times (in only driving it 3k miles, haha)...and hes used 5w30 each time. He uses 5w30 in everything we own. I am wondering if i should switch to 10w30 or if there is basically no difference between the two. Also keep in mind my car is only driven from approximately april-october.
five7kid
close
10W-30 will be fine.
My question is though, would there be any problem in switching to the 10w30, or would the transition be seamless?
whats the ambient temp you will be working at? since all numbers before the "W" denote a WINTER viscosity then both oils have the same viscosity ratining above 32 degrees (or 0 degrees respectively) both are a 30 weight oil at operating temperature.
thanks
J
thanks
J
five7kid
close
April-October driving in PA, 10W-30 will be fine.
The engine won't care that you're switching from 5W-30.
your dad changes your oil?
on another note 10w30 is prolly what i'd use
I'm 17. He used to be a GM mechanic from 1980-1990. He payed for alot of my car. He trusts himself more than he trust me. Nuff Said.Originally posted by urbanhunter44
A person has to learn at some point in time, though...
