Hydraulic roller cam install
Old Feb 25, 2006 | 08:34 AM
shawntmartin's Avatar
Engine: ZZ4
Transmission: TH-350
Axle/Gears: 3:73
Does this still need cam lube on all of the lobes like non-roller cams? I noticed Horsepower TV didn't have any on the cam when they were inserting their roller cam into a ZZ502.
Old Feb 25, 2006 | 09:06 AM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
Do not use any cam lube on a roller cam. Use what ever oil you will be putting in the oil pan.Apply it on all the jernalls and were it rides on the cam brg I also lube my lifters in oil also.
Old Feb 25, 2006 | 09:11 AM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Just lube the journals, and when you drop the lifters in, use some lube on the wheels. Anywhere metal touches metal you want a good lubricant. Regular oil will drop off before you fire the motor. I use Melling's assembly lube on that stuff, it's like a thick oil not a paste. Use it on the lifter wheels, timing chain, both ends of the pushrod, rocker fulcrum and the rocker tips/valve stem.
junkcltr
Aug 2, 2019 11:12 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
camaro71633
Sep 1, 2015 10:24 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
anesthes
Aug 8, 2015 09:37 PM
