Pro Magnum RRs - stock valve covers?
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Will a set of 1.52 ratio Comp Pro Magnum roller rockers fit under a set of stock perimiter bolt valve covers?
Also, I've heard of people saying that these rockers need longer than normal rocker studs? Is this true? Why? What studs do I need?
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
They work on a stock centerbolt with the little box inside ripped out. I have also used them with the stock factory studs (Although I wish they were longer)
NBrehm
Aug 25, 2015 11:49 PM
Street Lethal
Aug 12, 2015 11:33 AM
