wiring
Old Feb 28, 2006 | 06:58 PM
RandyZ's Avatar
Car: 1983 & 1993 camaro z28
Engine: 5.0 carbed/ LT1 injected
Transmission: T5/auto
Axle/Gears: 373/posi
wiring
i 'm pulling my tpi system out and i want to get ride of all the wiring can i just un hook the ecm AND TAKE ALL THE WIRE OUT ? WHAT WILL LOSE aND IS IT POSSOBLE.
Old Mar 1, 2006 | 10:16 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard.
Yes, you can remove all of the wiring by disconnecting at connectors. You'll have a hole in the passenger side kick panel. Other than that, you'll just lose the benefits of the TPI system.
Old Mar 1, 2006 | 10:26 AM
stitchop's Avatar
Car: 91 firebird
Be careful after you disconnect at the ECM and start pulling the wireing, there may be other wires; HVAC, ignition, lights, realys, and other wires that join the harness, or share the same routing under the hood at various locations.
Old Mar 1, 2006 | 06:10 PM
RandyZ's Avatar
I was hoping i could do that.now the ecm i don't nedd that i just take that out to right. and when you say harness you mean both that plug in the ecm,i hate to run around the subjet i just don't want to regret pulling somthing i needed.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
