need help with intermittent speedo
Old Mar 1, 2006 | 04:16 AM
warlord's Avatar
Car: 1983 Trans Am t-top
Engine: 305 4bbl carb (vin code H)
Transmission: 4 speed automatic
I have a 83 T/A 305 LG4 auto(700r4). my Speedo seems to work when it wants, e.g. it will work for a few days or maybe a week, then it will not work for a while and so on, also the needle wobbles at about 10mph and under.
I have done a search and think that maybe the cable is a bit seized and needs to be lubed.
I assume the cable is not broken as it sometimes works.
could it be a problem with the head? maybe a stripped gear causing the intermittent problem?
thank you.
Old Mar 1, 2006 | 09:56 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The low-speed wobble indicates a cable problem. Needing lube is a common cause, a kinked cable housing another. Do you have cruise control?
Old Mar 1, 2006 | 10:30 AM
warlord's Avatar
yes, i do have cruise control. could part of the cruise system be to blame?
Old Mar 1, 2006 | 11:09 AM
five7kid's Avatar
The cable goes to the cruise governor first, then to the speedometer. So, yes, it could very definately be a contributor.
Old Mar 1, 2006 | 11:17 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
my cruise control seized, causing the speedo cable to barely move, getting a weak, intermittent speedo, until the driven gear in the trans rounded itself to nothing. After replacing it twice, I removed the CC, and bypassed it with a normal 1 piece longer cable.
An easy check, unbolt your drive gear from the trans, should be 2 10mm headed bolts I think. (maybe just one...?)
and pull out the gear. If it's rounded, then you have the same problem as me. If it's ok, then plug it back in, and undo the cables at the CC module, and dump lube into the cables and re-try it.
Elephantismo
Feb 13, 2019 12:51 AM
Grant2k
Apr 4, 2016 08:21 AM
Reid Fleming
Oct 10, 2015 09:56 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
