Odd issue...
Old Mar 2, 2006 | 12:10 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Odd issue...
Ok, i just had 2 new valves put in this head because of this same problem before...
the exhaust rocker on #1 keeps turning a little, last July it turned enough to pop off the valve and break the rocker stud.
I'm guessing that whoever drilled and tapped the head for the screw in studs messed up on this one...
Anyone have any ideas on how to fix this?
Old Mar 2, 2006 | 12:31 PM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
I'm not 100% sure but I don't think you can use guide plates so you'll need self aligning rockers.
Scott
Old Mar 2, 2006 | 02:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Guide plates or self-aligning rockers, take your pick. You need one or the other.
Old Mar 2, 2006 | 02:10 PM
Looks to me like somebody drilled the push rod slots out of your heads, like they were prepping them for screw-in studs and guide plates; but there's no guide plates. So the rockers are free to wander around wherever they feel like.
If so, you need to install either guide plates, or self-aligning rockers; but NOT BOTH.
Old Mar 2, 2006 | 02:16 PM
five7kid's Avatar
Originally posted by sofakingdom
Looks to me like somebody drilled the push rod slots out of your heads.... [/B]
You mean 882's didn't come with round pushrod holes???
Old Mar 2, 2006 | 02:30 PM
Iunno..... it was just a thought... (well, not quite a thought, just a couple of the nerve endings in some ganglion somewhere firing at about the same time)
Old Mar 2, 2006 | 06:11 PM
Engine: 450HP 355
Transmission: TH350
So if i install guide plates, will i have to switch to hardened pushrods?
these pushrods are the ones that come with the XR270HR full roller retro kit.
http://www.powerandperformancenews.c...Code=K12-422-8
Old Mar 2, 2006 | 06:49 PM
five7kid's Avatar
Man, did you get ripped off! That kit is only $900 from Summit.
The description doesn't say anything about the pushrods. I'd say talk to Comp.
Pushrods, guideplates, rocker studs - by the time you get through, the self-aligning rockers might be cheaper (would certainly be easier).
Old Mar 2, 2006 | 07:29 PM
Engine: 450HP 355
Transmission: TH350
I didn't say where i got it
I ordered everything at one time and paid just over $1100.
that included the 1.52 rockers, pushrods and 3/8" studs. I ditched the double roller timing set in favor of a noisey Pete Jackson tho.
Old Mar 2, 2006 | 07:43 PM
Engine: 450HP 355
Transmission: TH350
well, i just talked to Comp. my pushrods are compatable with guideplates. I'm gonna go ahead and order a set.
http://www.powerandperformancenews.c...Category_Code=
I have a brand new set of rocker studs (missing 3) so this should be an easy install...
Mark_ZZ3
May 24, 2018 01:02 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Stryker412
Sep 20, 2015 06:59 PM
Fronzizzle
Sep 8, 2015 12:10 PM
BlackphantomZ28
Aug 31, 2015 11:19 AM
