sleeve or bore?
Old Mar 4, 2006 | 04:24 PM
ditchbangr's Avatar
Car: One of 5
Engine: LB9
sleeve or bore?
I just picked up a 509 400 that was taken out of a van at least 10 years ago because it was burning oil. It will be a spare block but I wanted to make sure it was a good core. I pulled off the heads and there is no ridge at all and quite a bit of crosshatch left in the cylinders. Hard to believe this was a carb'd engine. I have no way of measuring for taper. The only problem is one oil ring broke and left a gouge about 1.5 inches down the bore about 3/8" wide. It would clean up at .030 maybe even .020. Any suggestions on sleeving the one cylinder and saving the block for a overbore down the road? Or just go with the least amount of overbore and have at it? TIA, Steve
Old Mar 4, 2006 | 04:34 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
That's what I'd do. I don't even know if a machine shop would sleeve a 400 since the cylinders are so close together.
Old Mar 4, 2006 | 06:21 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
400's can be sleeved, but I would try to bore it first and see if it cleans up. If it does, then bore the other 7 holes and let it ride. Make sure to mag the block to be sure it isn't cracked and pay close attention to that particular cylinder.
FormulasOnly
Jul 23, 2018 08:47 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
hartsmike
Oct 2, 2015 07:11 AM
