Serpentine belt, A/C compressor Question
Old Mar 5, 2006 | 07:19 PM
Mathius's Avatar
OK, I didn't find what I was looking for with a search.... If I put a serpentine belt setup on an engine that didn't originally come with one, is it possible to hookup the a/c compressor to the setup and not actually hook up the a/c? I have heard that I might burn up the compressor if I did that.
I know that seems like a silly question, but I'd like to have a/c eventually, but it isn't a big deal right now (it's the dead of winter here and cash is always tight anyhow). I thought I would make provisions for it later, by getting the a/c version of the serpentine setup, but I didn't know if it was possible to just hook the compressor up without the a/c lines, evaporator, condensor, etc. or if I'd have to get the a/c delete pulley and hookup a compressor when I was ready to go full a/c.
Mathius
Old Mar 5, 2006 | 09:31 PM
marlow's Avatar
Car: 86 iroc 84trans am
Engine: iroc 350 trans am HO 305
Transmission: t5
you should just get the belt without the ac to avoid the problem of no oil to the compressor which could fry the compressor
Old Mar 5, 2006 | 09:42 PM
LnealZ28's Avatar
Car: 1987 Z28
Engine: 383 Single Plane EFI-NOW RUNNING!
Axle/Gears: Not there yet...
If you don't try to run the compressor it won't matter. You will not harm the compressor as long as you leave the a/c clutch wire disconnected until you get it fixed properly. When the a/c clutch is deenergized the compressor IS NOT turning.
Old May 8, 2006 | 08:19 AM
codemonk84's Avatar
Car: 1999 Camaro SS
Engine: 5.7L LS1
Transmission: 6-speed
Slightly off the original question but this seemed closest I could find searching for an answer...if I disconnect the wires to the A/C compressor (that's the thing driven by a belt right?), and then remove it from being turned by a belt at all, it won't damage anything? (I intend on removing my A/C altogether later on...right now, I'd just like to start on it bit by bit).
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Apr 14, 2016 08:52 PM
mustangdmurder
Aug 21, 2015 07:17 PM
redmaroz
Aug 16, 2015 11:40 PM
jahblah
Aug 12, 2015 05:54 PM
