Idles High Only On Start Up
Old Mar 5, 2006 | 10:25 PM
zrated57's Avatar
Just wondering why my '85 Camaro Z28 idles high only are start up and never after that. As soon as its started it'll jump to 1500 RPMs, hang there for about 5 seconds and then slowly climb to normal idle RPMs? Any answers?
Old Mar 6, 2006 | 12:26 AM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
the IAC is either open or closed whichever is the at rest setting then it slowly works its way back to the ECU controled idle.
Old Mar 6, 2006 | 02:04 AM
zrated57's Avatar
Is there a way to eliminate the high idle at start up? What do I need to do?
Old Mar 6, 2006 | 03:08 AM
Vader's Avatar
You can reprogram the target idle adder versus coolant temperature parameters, the added IAC steps for cold start, and the start timer. The factory programming runs the engine at higher RPM during starts, then steps it down to the "normal" warm idle RPM. That's completely normal.
Old Mar 11, 2006 | 03:39 AM
zrated57's Avatar
How do I reprogram the target idle, IAC cold start and start timer? Is that something I can do myself?
Would replacing the IAC help out at all? Or maybe recal. the TPS?
Orr89RocZ
Apr 25, 2016 08:28 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
