Fuel pressure
Old Mar 11, 2006 | 04:13 PM
teapot3208's Avatar
Car: 1985 Camaro
Engine: 350 .030 over (355)
Transmission: 700-R4
Fuel pressure
My fuel pressure jumps from 0-6psi when its runing (with the engine, if that makes any sense). Im slowly starting to experience harder starting and it idles not as well as it used to. Its off the old 305 and I put it on my 355 when I did the swap. Its a stock mechanical fuel pump. Do I need a new one?
Old Mar 11, 2006 | 06:50 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Ya, that's where I would start, shuold be a pulsing 4-6 PSI reading on a mechanical pump.
Also, take a sniff if your oil, see if it smeels like gas...if so, change it along with the FP.
Old Mar 11, 2006 | 10:04 PM
teapot3208's Avatar
Car: 1985 Camaro
New pump is on and it seems to run so much better.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
