Intake repair
Old Mar 13, 2006 | 11:45 AM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Intake repair
One of the carb studs in my intake was stripped out when i purchased it. What is the best way to repair this?
helicoil? Is it worth paying a shop to do? Is there a kit available for this repair?
Old Mar 13, 2006 | 11:51 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
heli coil is the best bet, don't pay someone to do it just go to your local parts or hardware store and buy a kit, shouldn't run ya over 6 bucks. They are very easy to do, you simly drill to appropriate size, tap and install the thread insert, anyone with basic ability to use tools can do it.
Old Mar 13, 2006 | 11:56 AM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
So the tap and insert is all included in the kit? I just need a drill and a bit?
Old Mar 13, 2006 | 12:00 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Also what size thread are the carb stud holes in an edelbrock intake?
Old Mar 13, 2006 | 12:49 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I tried to get an M6 helicoil kit here, since it's a weirdo "helicoil" tap, and you need an install tool, it was $54. So I think $6 might be hopeful, but hey, here's hoping you get a good deal.
I think it's a 5/16" NC hole.
Old Mar 13, 2006 | 07:27 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
My Helicoil kit at Autozone was $20, and I think I still had to get the bit at Home Depot. But it worked.
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
toronto formula
Sep 10, 2015 07:31 AM
Stryker412
Sep 7, 2015 09:11 AM
TheExaminer
Sep 6, 2015 11:40 PM
mrdevontay
Sep 2, 2015 08:04 PM
