compression?????
Old Mar 13, 2006 | 02:36 PM
z28maro's Avatar
Car: 1983 z28 camaro
Engine: 305 - LU5 bottom end.
Axle/Gears: 2.93 stock :-(
compression?????
yesterday i did a considerable amount of work on my car cylinder heads up as well as a hot cam. i go to put in my distributer so i go to turn it to tdc and i have next to no compression. im positive the head gasket is good. im next to sure my piston rings are sealed. the only thing i think it my be is something to do with the cam. would that have anything to do with it? cause im atleast 90% sure i lined up the timing chain correctly and dont want to take it out if i dont have to. does anyone out there have any ideas?
Old Mar 13, 2006 | 03:10 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Rocker arms adj'ed too tight??
Old Mar 15, 2006 | 01:12 AM
z28maro's Avatar
that was it. i found out probably as you were posting but thanks though
FormulasOnly
Jul 23, 2018 08:47 AM
69GTOby
Apr 18, 2016 02:34 PM
Nervous2
Oct 8, 2015 10:53 PM
Jonas Earl
Sep 27, 2015 07:39 AM
WhteRbt
Sep 21, 2015 09:48 AM
