will the hotcam pass emmissions?
Old Mar 5, 2006 | 11:06 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
right now i have a 212-218 487-495 cam and i dont have any smog stuff on the motor the proms egr is off, and ive been told i can pass emmission the way it is...i just need to back the timmin down and make sure the motor is hot, not sure if this is true or not but, how hard will it be for the hotcam to pass? im guessin ill have to put all the smog stuff on "not the air pump" to pass!
Old Mar 6, 2006 | 01:01 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
The HOTcam will even pass CA emissions. However there are much better choices than the HOTcam that will still pass.
Old Mar 6, 2006 | 01:05 AM
Car: 92 1500p\u 2wd
ok im interested what other cams are better and will still pass?
Old Mar 6, 2006 | 01:39 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
From a TPI standpoint, that cam you got is a mother of a mid range torque puller on a 350.
Love it in my friends car.
They also make the one the next step up in a 218/224 and I believe .498/.498 lift that I like too.
I've run the hot cam and it should pass emissions just fine with a proper tune. Mine went thru the IM 240 style here cleaner than my 91 GTA(stock) without the AIR or EGR functional.
Personally, if your keeping TPI, from what I have learned and experienced, I would go with something of a less severe split duration than 10 degrees from intake to exhaust.
Again just my opinion.
later
Jeremy
Old Mar 10, 2006 | 06:13 PM
Car: 92 1500p\u 2wd
"step up in a 218/224 and I believe .498/.498 lift"
would this grind give my a good boost in getup and go over the 112-118 487-495 110 i have now? im just lookin for a lop in the exhaust and it to have some more power thats all......right now im runnin stock exhaust manifolds and stock "truck: cross pipe so im guessin when i get my longtubes on and my exhaust reworks it should give me a nice jump in power...this motor in a 92 fullsize truck!! i just love the sound of the hot cam and have herd you can make great power with it....i have a high-flow tpi setup thats goin on soon...i have the edelbrock base on now and the ported slp runner/ported plenum is goin on sson, i dont want to loose a lot or low end grunt.,...imo thats the fun part...intown messin around. its a truck so i dont need to go 150mph....quick is good for me..but i would like to beatup on some sports cars out there!!
Old Mar 10, 2006 | 06:15 PM
Car: 92 1500p\u 2wd
why do you say this...im just wondering... i have a lot to learn!!! thanks again
Old Mar 10, 2006 | 10:21 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
At least put the EGR back on for the time being, it makes a big difference. Though all of this really depends on your state. My car came from Texas where they still have stations that just roll you through the door only checking things like head lights, horn, that you have 12.50 in your wallet. Keep in mind that getting it tested in or near a busy city will be more harsh, drive out a lil further into the boon docks and find a gas station that happens to do emission testing. If you fail, you usually have 14 days to fix the problem and come back for a free retest.
Old Mar 10, 2006 | 11:29 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I ran the LPE219 cam with my LTR setup. Passed perfectly with just a cat.
Old Mar 10, 2006 | 11:30 PM
Car: 92 1500p\u 2wd
even if the egr is off on the prom i can still hook up the rge and it will work a lil? i have allt he egr parts but i havento installed them. all we have is pop the hood hold at 2000 sniff the pipes and thats it!! 15$ so i hope i can pass
Car: 92 1500p\u 2wd
LPE219 cam how big is this cam?
Old Mar 10, 2006 | 11:42 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
duration is 219/219 and lift is .560/.560 with 1.6 rockers
Old Mar 10, 2006 | 11:57 PM
If your ECM sends no message to the EGR solenoid, it would keep it closed resulting in the EGR doing nothing. Bypass the solenoid and just hook the EGR to a vacuum source. All the solenoid and ECM do for the EGR is provide finer control over when it opens and closes, it sould still work without the computer controling it. Might want to test drive it a bit after doing so, to make sure that its not letting to much exhaust into your intake.
Old Mar 11, 2006 | 12:56 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
I passed the "idle / 2.5K RPM" sniffer test running a LPE 74211 cam and no cat. AIR and EGR were functional.
Old Mar 11, 2006 | 09:51 AM
Car: 92 1500p\u 2wd
i took the air pump off and the ecm is off for egr, so im hopin i can pass with just 2 new high-flow cats and the right tune. if not then i can try to turn on the egr and hook that up or just hook up the valve and bepass the sensor .......
Old Mar 11, 2006 | 11:51 AM
hope it works cause I'm trying about the same thing, I'll let you know how it goes.
Old Mar 15, 2006 | 01:29 AM
Car: 92 1500p\u 2wd
what about the tpis 700-135 cam 280/280-224/224-.495/.495 112?
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
